No Heat!
srspicer
Hi Everyone,
I have a problem with my 03' Grand P., GT. There is no heat!:th_wtf:
The blower works, I can hear the vacuum hoses working when I use the selector, A/C works. No coolant inside on the floor. Has anyone had this problem, can I fix it myself?
Thanks in advance for your help!
Scott
Nope I never have had this problem.
Check your radiator coolant level, when the engine is cool. Your radiator should be basically completely full. If not add Dexicool, if you’re in a pinch you can add distilled water. Just check the freezing point ASAP afterward.
If your level is good, get back to us.
Ya see?!
This is why I joined this forum! I have had great advice on another forum ( CRX) and this forum is no different.
cerick08GP, you were right, so far. I had not filled the system enough! The heat is working.:th_thumbsup-wink:
Thanks much.
Scott
If you were that low on coolant remember to purge the air out of the system, especially if you're still running DexCool.
