No heat blowing in the car
jbaker4433
I have a 2005 GP base model with a 3.8 Series III and I have no heat blowing into the car. Blower motor works, fluid level is full, but still no heat. What could be the problem and how do I fix it?
@jbaker4433, I can understand how frustrating this must be for you. Did you get this taken care of? Did you contact the dealership to see if they could offer any avenues for you to try to follow to get to the root of this?
Michelle, GM Customer Service
there are two one on each side under the dash near the center concole. If you have digital heat they are about 68 bucks each about half that if you dont have digital. My car is older than yours so it may not exactly be the same. i found an article on here how to replace it.
same problem with my 07. Dealer said I had an air lock, bled the system and problem went away. I also had the gurguling sound, 1st time was water in blower area and second thin they did the above.
