Had the owner of the 01 GT come over today so he could help me bleed the brakes. Backstory, I had to remove the 4 lines from the top of the ABS module in order to install a new fuel line (feed side). Nothing is leaking fluid anywhere.
Started at the right rear as usual and noticed I wasn't getting anything. Pulled the banjo bolt and cleaned it out. Still nothing. Left the line off the caliper and had him press the pedal gently. Nothing more than a drop or 2. For a test I undid the left rear and repeated. Fluid shot out like it should.
Installed a new brake hose on the right rear and STILL nothing more than a drop. I'm not sure what else could cause this other than maybe the aluminum proportioning valve that is right before the brake hose on that side.
Anyone else have a better idea before I replace that valve?
So much for a 1 hour brake bleed....
