No Cruise or Tapshift
awrage
My 04 gp gtp comp g recently had the cruise and tap shift stop working. Ive replaced all the cooling in the car so finally thats all good to go. But now the cruise and tap shift stopped working.. Ive checked all the fuses and everthing else related to it that I can think of. Also no codes present. I dont know why it stopped need help. Thanks
Check all your brake lights just to make sure one bulb is not out. If the 3rd brake light is out, CC can stop working.
Or the brake light switch on the pedal is sticking/bad.
I'd look at those two things first.
I had a bad crank sensor that made the cruise not work.
Tapsh*t sucks anyways. I almost never use those, so I would've had no idea. Lol
Does it disengage cruise while driving? That's what ours starting doing before the balancer took out the cps. Well... so then I had a bad harmonic balancer and the cps was fine, really. Lol
If there's no code, I'd give that balancer an inspection around the rubber edge. It could be deteriorated. I didn't notice the engine shaking any more, but when I put a new balancer on there was a definite difference.
