I have done a ton of research on nitrous and I decided that I'm going to go with it and do a 50 shot because that will put me at about 300 hp to the wheel and that is my goal. and this will be the cheapest way to do it.
my current mods are rebuilt engine (50,000 miles ago) rebuilt transmission (100 miles ago, GT transmission) CAI, u bend is gone and got a high flow cat and resonator, zzp 1.0 pcm, voltage booster, double platinum spark plugs, #90 springs, 180 t-stat, new plug wires, complete top swap, GT1 cam (did this before top swap, says it works great with boost tho) and i got it dyno tunned.
so my question is what do you all think are all the necessary components needed to safely run a 50 shot of nitrous. and I decided to do a wet shot because that seems to be the safest.
also keep in mind that this is my daily driver in the summer, obviously I'm only going to use it when I have to and only at WOT, and not through the shifts.
