Newbie help... 01 Grand Prix Vibration
bunnyboy
I have a vibration that is only happening when I go over bumps( more like Dips) over 50 mph. Also getting similar vibration on the car when I take curves to the right but not to the left.
I have jacked the car up and the wheel bearings feel okay. There is a little play in the tie rods and ball joints. My father thinks is the combination between the tie rods and ball joints but I don't think so... Can someone give me some insight here.... I don't think its the tie rods and ball joints....
Help, I don't want to spend money I don't need to.
sounds like the problem to me anything loose in the front end will make the car shake, especially at high speeds replace the loose parts and go get a allighment before sumthing bad happens:th_thumbsup-wink:
Im getting the same thing, bumps at high speed (vibrates) and right turns under power give harsh vibration on right side, but no vibration on left turns.. I was told on here it was CV joint really confusing...
