New to the Forum just bought my first GTP
motoshrump
Hey there,
Just drove home my first GTP today. It's a 2002 Titanium colored fully loaded model with 90000 miles on it. It's practically all original (except the brakes of course) and requiring a set of struts (the roads are rough here) a couple of wheel bearings and a left front fender.
I consider myself a backyard do it your-selfer which explains the project car.
My first question is in regards to engine oil. The car has had conventional oil all its life with the second owner ( I am the third) and I personally have had the best luck running Castrol GTX with early oil changes on all my vehicles. I also use Black Label WIX filters religiously on eveything
What would be best for the Supercharger? Stick with a good conventional oil or go synthetic? The engine is super quiet and the previous owner ran 5W30 in it. We have the same kind of climate as Massachusetts / Upstate New York so the lighter weight oil hasnt had a negative impact on the engine that I can see.
With 90.000 miles on it I figure I am safe to go through with a change in oil type.
Any suggestions out there?
Thanks in advance
Hey there,
Thanks in advance
okay, so oil for the engine or the supercharger? the supercharger has a special oil. the oil from the engine does not lubricate the s/c they are separate. im not sure if that helps or what you were asking exactly?
Okay, I am starting to understand how GM has built this engine. If the S/C has an independant oil supply then how often should it be changed and how do I go about doing so?
