New Self Sealing Bulkhead fittings
  • Thread starter Thread starter DevilsOwn
  • Start date Start date
D
DevilsOwn
Guest
Self Sealing bulk head fittings
Drill a 7/8" hole in a flat location and simply place it in and tighten and slide in your 1/4" tubing.
No need for cumbersome bulkhead fittings when you can use DevilsOwn Injections Self Sealing Bulk Head fitting.
Design Features:
* Intergrated 1/4" push to connect fitting
* Buna-N sealing components
* Easy installation
* Suitable for a wide range of liquids
Design Specs:
* Material:Polypropylene,PVDF
* Max.pressure:10bar
* Max.temperature:100℃
come by here and pick one up then :) I didn't have them when you came by.
Just giving you a hard time man! LOL
Thanks, but i'll stick with what I got. It should work flawlessly IMO. That washer jug is ALOT thicker than I ever thought it would be. I couldn't believe all the threads I tapped into it. I bet I tapped in at least 4 or 5 threads! After seeing that I knew I'd be fine. I have a new found respect for the factory washer tank, let me tell ya.
This bulkhead is super nice though, I remember seeing your level sensor which seals off the same way. Makes tapping into the washer tank damn near fool proof, plus it looks pretty damn neat.
