New product Self Sealing Filtered Bulk Head
  • Thread starter Thread starter DevilsOwn
  • Start date Start date
D
DevilsOwn
Guest
No need for awkward bulkhead fittings when you can use DevilsOwn Injections self sealing, "self cleaning" filter.
Because the cone-shaped screen is placed outward against the flow of the water-methanol mix, it deflects the debris that would clog or damage components of the methanol injection kit. By forcing the debris to the gasket area, the result is a filter that will naturally clean itself. Also, by capturing and getting rid of the debris, it will help extend the life of your system components.
Our standard bulk head filters are made of T304 stainless steel wire cloth and are approximately 120 microns. In addition, the fittings are very simple to install from the outside of any tank. Drill a 7/8" hole in a flat location and simply slide it threw and tighten. The outside has a built in 1/4" push to connect.
Design Features:
* Intergrated 1/4" push to connect fitting
* Buna-N sealing components
* Self cleaning filter
* Easy installation
* Suitable for a wide range of liquids
Design Specs:
* Material:Polypropylene,PVDF
* Max.temperature:100℃
Yes you can run 100% methanol through the whole system. If you have any other questions about a setup, give us a call @ 405-227-0597.
