New Hub, ABS Light Still!?!
trailshredder
Had the ABS light coming on. Had the ABS codes scanned and had a C0040 and a C0245. I replaced the right front hub this weekend and my ABS/trac control light was still on. Wires from the sensor look fine. I disconnected the battery for 36 hours. Reconnected this morning and it is still on. Does this have to be cleared with a scanner?
It will clear on it's own if the problem causing it is fixed. Any chance you got a defective hub since you say the wiring is good?
Guess it could be. It was a Timken ordered online from rock auto. Any way to narrow it down, other than swapping with the otherside?
