EHB
hi fellas . just bought a 2000 GTP with 117000 miles on it. thought i was gettin a steal at $1300, but the guy who sold it to me left out a few details on what was wrong with the car. found this sight while trying to diagnose a few problems. i foolishly handed over the cash before even looking the car over . he told me all it needed was brakes, rotors , emergency brake cable (which he said was on the back seat but doesn't fit the car) and said it had a fuel line leak.
what he didn't tell me was ...
dead battery
abs light on
SRS light on
traction control off
horn doesn't work
heater motor doesn't work any speed
onboard display thingy doesn't work
radio doesn't work
wipers when shut off is in strait up position instead of down
drivers side power seat motor doesn't work and is stuck all the way forward so i can't even get behind the wheel.
transmission line leaking somewhere
body is in good shape , few scuffs scrapes and scratches here and there ,but no rust.
the engine sounds great , idles smooth, and my mechanic took me for a test drive after he put the brakes and rotors on it. he's a little fella and can fit in the seat.
problem is he said the brakes are spongy and need bled and he's not hopeful he'll get the bleeders open so i'll probably end up buying new calipers not to mention whatever abs problems arise ...please don't be wheel hub assembly..PLEEEEASE!!! ...
also not to confident that things like tyrod ends and the sway bar will pass inspection.
if any of you guys see a pattern with the electrical issues and can point me in a direction trouble shooting wise , i'm all ears . i've read online that the ignition switch is a common problem.
dead battery
abs light on
SRS light on
horn doesn't work
radio doesn't work
