new from AZ about to buy my first GTP
taman86
Hey there new on this forum and about to purchase a 97 gtp coupe. Has quite a bit miles but I'm fairly confident about the car. I guess this would be my second GP experience the first being my ex-wifes 02 se. I mostly spend my time over on ls1tech and have personlly owned ONLY trans am's. Three of them to be exact so this is my first non trans am but still keeping it pontiac.
Hey there fellow ls1tech'er. Different profile pic on here then ls1tech but I figured I would make the avatar forum specific
I'm from south east az in graham county.
The t/a ran 12.02 in the 1/4 full weight and street tires but the car isn't setup for straight line its set up for corners and going as fast as possiBle in those corners
Good! It's nice to see something other than a stipper f body. Does it have an suspension mods at all?
Ya it has full lg suspension minus the tubular k-member and udjustable upper a arms. So the list is adjustable lower a arns adjustable tq arm adjustable pan hard rod adjustable lower control arms control arm relocation brackets stock bilsteins with eibach pro kit and all suspension pieces poly seperical rod ends oh and 32mm front solid sway bar and 23mm solid rear sway bar and bmr strut tower brace and kenne brown double diamond sub frame connectors. Like I said full suspension
