grandprixfamily
For a several years now, I have revised, redesigned, and played with this idea of a lower motor mount that completely eliminates the upper dog bones. Part of the engine vibration issues we feel in the cabin are due to the motor being supported by the front unibody framing above the radiator that directly transmits vibrations to the passenger cabin. Ive wanted a stiff and non moving engine, without the rattles and issues that usually accompany it. I know that cars that do not have the upper arms tend to not transmit these vibrations. However, short of crazy cradle changes, sometimes even the transmission casing itself, there was no easy solution.
Behold, the solution:
Mod Writeups by Ryan Cape | Photobucket
http://i51.photobucket.com/albums/f... Writeups/IMG_20180413_162722_zpsxqx8puit.jpg
http://i51.photobucket.com/albums/f... Writeups/IMG_20180413_162732_zpstnzxynlt.jpg
http://i51.photobucket.com/albums/f... Writeups/IMG_20180413_162738_zpsr59zefok.jpg
http://i51.photobucket.com/albums/f... Writeups/IMG_20180415_210608_zpspwwch2ze.jpg
http://i51.photobucket.com/albums/f... Writeups/IMG_20180415_210622_zpsenfjkeen.jpg
http://i51.photobucket.com/albums/f... Writeups/IMG_20180415_210655_zpskbfu1ib6.jpg
This is a 1/2 inch thick aluminum plate, cut and shaped to follow the contours of the transmission. The tube at the bottom holds one of the original dogbone arm bushings. The angle brackets are also 5056 T6 aluminum. A steel plate with nuts are tack welded on, and slid inside the passage of the aluminum cradle for support. On a steel cradle car, you can tap and bolt directly in.
NO engine movement, but also still completely rubber isolated. There were previous versions of this mount, but they relied on just a single bolt hole, no rubber mount or isolation to prevent false knock readings, and were too harsh.
I am considering making more, making kits that can be installed in a few hours. Hardest part is lining it all up and drilling the holes in the cradle.
