New build for the gsx
CrazyGuy03
Sorry I didn't have time to copy and paste the entire thread over.
But if anyone is interested , it's here http://www.regalgs.org/topic/58752-new-build-for-the-gsx/
nothing major like a csc or turbo but m90 s3 cam and heads build (maybe now I will put my slp stage "3" badge on) ;)
L26 build
Edited 5/20/15 Copied all the pics over from the regal site Lots of pics to pass the time
Waiting
Super clean -
The heads look amazing too bad I can't use em
Will re use the rockers
GM valve seals - green for exhaust blue for intake
Only thing that didn't like sitting all these years was the dex cool. Very bad stuff / I'm willing to bet if it was green coolant, it would be a lot nicer looking in my water ports
Block looks great. Can read every date code even on the bottom of the oil pan
The big controversial bottom end
Stripped down for cam/ double roller
lol you're on the right track, well corn at least ;)
The 130lb spring I was missing came in today -- Friday hopefully my l67 comes out ! Yay me. Then slowly swap over the parts I'm re-using. I say slowly because I like to clean as much as possible.
Justin and I slowly working at it
That custom surface-ground oil pump cover from Gr8tracingfool worked like a charm with a single metal gasket
I've been working at it here and there
Chased the bolt holes. Cleaned them
Up.Used high temp thread sealant by permatex
10ft/lbs to make sure they are seated
Coated the gaskets. Letting it dry. Then hopefully today assemble the heads.
That's about as far as I can go until I need parts from my current motor to continue.
Thanks ! I know I said this before but it's fun watching your build as well. Wonder who will be done first ? Bill said you work slow... Well he never seen me work haha
plus I have 5 rolls of sticky tape ;)
im lacking a hoist still. that will be the next hold up lol
i was waiting for the die grinder bit for the heads. there was no reason to start any thing else until the heads were done. now i look at shinny heads as i walk to a dirty engine that needs TLC still lol
ill be up to your speed tomorrow. and we will be both waiting for parts off the running engine. im not even putting my heads on till the day my engine comes out. i need the springs and rockers off it. im not putting the stock springs back on just to swap em again. much easier heads off to get the springs on too.
Wise man learns after his first teardown that cleaning the motor prior to teardown is easier. I learned the hard way too.
Scott, I thought you had a compressor and could put the springs on with the engine together?
Bob.. please spray brake cleaner on a rag and wipe out the freeze plugs. It's amazing how much nicer it'll look
I hope you both have some Purple Power/Simple Green on hand for when you yank the motor. That day.. the car should be sprayed liberally in the engine bay and hosed repeatedly. Clean it right up and install will be much better/cleaner.
ps..it installs this side up
Great idea Bill. I like your attention to detail.
Also - the part I'm anxious for is the engine bay cleaning. No idea if it's even possible to get it perfect. Then comes the topic of debate - to roll on / spay on some rust oleum or not
When i did my rebuild i cleaned the shat out of that motor.. Simple green brake cleaner ever dang thing.. Crazyguy.. What brand of paint did you use?
Bob, I pulled out the pressure washer. Sprayed down the bay with cleaner first.. Pressure washed.. sprayed down again and again with pressure in between. It'll come super clean.
I believe its dupli color ? Engine paint .
Once the motor and parts are painted , I use a spray bottle with csr soap and water mix to clean the engine. Anything else hurts the paint and ruins it. It's a trade off for not using powder coat I guess
Bill - good idea. Just don't have a working power washer at the moment ....
For the support braces and other red parts not getting too hot, I use rustoleum sun burst red or sun fire red. Works great
Justin and I started to remove the L67
Came out the side pretty easy with trans still in car
Sitting on a custom pallet for the motor
Made the "custom" L67 motor mount bracket fit the aluminum oil pan. Just need to make 2 small cuts and its perfect , just like Bill said it would ;)
