new battery? maybe?
tcafego
Ok so the negative cable connecting the battery seems stripped maybe. It doesn't tighten snug like the positive. It just kind of sits in there. Doesn't tighten at all as much as I spin it. Anyone know if I.should just buy a new battery or is it more simple than that?
Remove it and find some bolts the same size as the terminals....if it screws in the negative, your problem is the -terminal connector. It will save you from buying a battery if its not necessary.
