Hello everyone I had a couple issues with my l67 upon fixing them other things are popping up and I'm looking for experienced advice.
So car is a 98 GT Coupe(stock L36) that i top swapped.
Exhaust (Manifolds crossover and DP) is all stock except u-bend delete.
Ported gen 3 M90, and ported LIM, running stock 3.8 pulley. CAI, 180* thermostat, autolite 103's, and ZZP 1.0 PCM tuned for 91 octane but running 93. Approximately 3k miles on top swap.
It started a couple days ago. Car ran exceptional decide I'm gonna go to the track for some fun. Figure it would be best to scan and make sure everything is in order. Everything looked good no knock, car pulls hard then i notice my LTFT lingering around +16%. Grabbed some carb cleaner thinking i had a vacuum leak, found 3. a leaking hose on SC tree, leak at PCV and EGR. sealed them all up no more leaks. However now my LTFT are inbetween -16% to -26% at idle, cruise, or decelleration.
During acceleration under load the fuel trims even out to acceptable numbers but as soon as i let off throttle they go back to high negatives. Peaking around through torque scan i noticed during idle if i blip the throttle a little bit I'm getting random misfires upon revs dropping to normal. According to torque scan all my cylinders occasionally misfire with #'s 4 and 5 being the worse. Pulled all the plugs and they all look the same a bit white probably from running lean with leaks for however long but not bad.
Reinstalled plugs. decided to throw in another FPR i knew was good i had laying around because i smelled faint gas in the vacuum hose. Unplugged battery for a few hours to reset fuel trims and took her for a spin. Feels good but LTFT are still chilling around -20% and i noticed 2 degrees of knock during a 2-3 shift at WOT. So i park to check things out. I'm still getting occasional current misfires in all cylinders but 0 under history not enough to trigger CEL apparently. But i can feel the surge and shake from the mis at idle. I snapped the throttle under frustration to hear that sweet SC whine and i noticed my scangauge read 7.3 degrees KR. Another thing i just noticed is slight gas smell in oil i will do a change asap.
So to reiterate car ran good with vacuum leaks aside from high + LTFT. no knock under any condition. Not sure about the misfires though. After fixing vacuum leaks it would appear im running too rich and its causing me to knock like a mo fo.
MAF, MAP, TPS, IAC, and ECT sensors are relatively new and showing correct values. O2 sensor was replaced 10k ago and I'm not sure of normal operating specs for that.
I do hear an occasion tick or click from DP/CAT area at idle. Anyone have experience with ZZP PCMs? Do they tune them on the richer side causing my LTFT to be high negatives? Do all engines have occasional misfires? Is it something i shouldn't worry about until it triggers a CEL?
also i thought KR was more prone to happen when running lean. How come i had no knock with vacuum leaks causing lean condition. But after fixing leaks and now running rich i have knock?
Any ideas? I don't know where to go from here besides making vacuum leaks to even out trims.
Also does anyone know if an exhaust leak before upstream O2 would cause a lean condition (high ltft) or a rich condition (low ltft)? this may be my problem though the leak would be small because it's not that loud.
Any advice or info is appreciated. Educate me!
