Negative Camber front passenger sde
chevy350
I have a 2001 grand prix. That had a fender bender on the passenger side. When I bought the car it needed a fender. So I'm taking it that the accident may have bent a suspension part. When the steering wheel is straight it pulls to the left, Everything is factory.
It's funny I took it to a few suspension places to check the suspension,(before I noticed the wheel camber)and no one ever mentioned or noticed it.
Would that be an control arm/ball joint? or would a alignment Kit work.
Get it on an alignment rack and see whats out.
Either the toe it out from the fender bender or you need camber bolts/holes drilled bigger on the struts to adjust them within spec.
