need tune for 2002 gtp
bocou92
Anyone have a tune for a 2002 gtp with these mods:
Cold air intake
160 thermostat
Speed daddy headers
Zzp 3" stainless steel cat back with cat
I'm on a 2.8 pulley and I run a 180*. 160 is way too cold for a near stock setup.
it doesnt really run @ 160 it runs like 175 or 185, but if the 160 could cause damage to the engine then i will. but i need a tune for my other stuff i have, going to, put on
Don't need a tune for some exhaust and an intake.
If you really want to run the colder t-stat, then yes, you'd need a tune to change your fan settings, but that's about it.
Just got the cars to stop knocking, then from there raised the shift points a little and had the trans shift firmer/faster.
One guy in a Regal GS was running 15.1-15.2 all day and I talked him into a tune right there at the track... next pass was 14.5.
Yeah a tune can defiantly help, but if you don't have constant access to a tuner then tuning at every small change is kinda pointless. If you plan on going further in your build, wait until you drop a pulley, get a cam or something that really changed how the motor flows.
Tune helps on any car, regardless of mods.
Trade off the 160* for a 180*.
Get new wires/plugs if you haven't. Flip the factory mounts.
Lots of little things you can do to help the car.
Help is a strong word but I dont disagree. I wouldnt tune a car unless I had to and ive flashed over 2000 files to 3800s in my day.
