need to know
06dmax
on my 06 gp what should my tranny temp run?gonna change the fluids in it what do yall recomend and how much fluid.
tc lockup is at 80* so when warmed up you should see anywhere from 150-190 range, preferably in between. Amsoil works well, of course its also $11 a qt.
If you are still running the stock thermostat and pcm tune then you will likely see trans temps in the 180-210 range after everything is fully warmed up as this is what I have seen on the 04+ models on the driver info center during a long cruise.
yeah I have an 06 with stock termostat and stock PCM, I think mine runs about the
215* range, Trannyman is dead on lol ;)
duno on fluid amount.
