Need some help
Minno
First off, if anyone has pacesetters, tell me how to fix this y-pipe leak. I have tried different clamps tightened em down but it still leaks, and I even have the supposed "zzp fix". This **** is pissing me off badly. Second, I have a massive coolant leak coming from somewhere on the back of the motor. The cap on the power steering pump is wet. The heater hoses are not cracked and the idler itself does not appear to be leaking. I have had coolant issues for a long time and im getting really sick of them. If anyone has any advice let me know, please. Thanks.
that sux...... those were in my price range..guess ill have to save for the s&s if those suck then the slp
Bah, paint is deffinately crap, but if you get the hot coated ones they will not discolor.
Get two of these from NAPA, part # 733-3220, and use some high temp RTV. This will fix the leaking problem, and they're stainless clamps to boot.
Yah, they are honestly the best though because of the large primaries. Thanks Reptile ill have to check those out. I am starting to think its leaking at the head now! I am gonna check with soapy water tommarrow to make sure. If it is indeed the y-pipe leaking then ill get some of those clamps! :) BTW Coolant issue is fixed, just was a mistake haha.
