Need more input for stock 3.8 NA
03GPScottyd
We need a lot of input in this section, maybe put together a post on how to make my NA faster or well have 20 new post a week posted on the same topic.
I used to have a FAQ I wrote way back when when I had my GT. Ill try to find it.
THANK YOU!!!
I always get shit from my local club about doing mods to my GT, like taking off the speed limiter.
THANK YOU!!!
You do? Never saw that I guess. I don't recall the last post you even made about modding it. You must not be talking about KCPMC.
1.9 rockers, LS6 springs, tune, CAI, 3" DP, PEM's, and a sticky tire.
this should be pretty potent for N/A. and if you have time go for a cam/spray.
Yep, although I'd change the 1.9's to the ER Ratio that ZZP sells. If you're running FWD then the HV3 is a sound investment also.
Sorry guys. Sounded different in my head than it did when I was typing it..
I take back what I said earlier and offer to wear a "Dunce" hat for my stupidity.:o
Im new to this forum. Thought I would throw my 2 cents about modding N/A's, since I still have a N/A GP.
Ive got the stupidly exspensive K&N FIPK air intake, DHP 1.0 PCM, Comp Cams Xtreme Energy L36 Cam 2, Comp Cams Pro Magnum Hydraulic Lifters, Comp Cams High Load Valvesprings, Comp Cams Hi-Tech Pushrods, 1.80:1 High Ratio Modified Rocker Arms, 3" DP w/ Cat, Flowmaster Exhaust *workin on headers* so basically i bought off of 3800performance.com
A cam and 1.8 rockers?? Better be sure you can run those with the cam. Otherwise I see a L67 swap in your future cause your gonna damage something.
