TuKoolGTP
I have run new wire harnesses for the head lights as well as the fog lights. I am using the factory wiring to turn on the relays for the new wiring. I am also running the Spyder projectors. I added diodes to turn on the Low Beams and Fogs when the High Beams are on, as before they would shut off.
Current Behavour.....
With Fog Lights off, Low and High beam work perfect. (All 6 lights on with high beam)
On Low beam, Fog lights turn off and on with the factory switch.
Problem...
When on Low Beam with the Fog Lights on, I can switch to high beam. But when I go back to Low beam, All 6 lights stay on.
Any Ideas?????
Problem...
Any Ideas?????
