Need help
hulkprix51490
so my car had problems starting it just cranked, cranked, an cranked then start an after a message said reduced engine power came on an these codes are what came up when I ran them p0606, p1518, p0113.
I would go and unhook the battery negative for a few minutes, hook it back up, and see if the codes pop back up.
While you can drive it like that, it's not a good idea to.
if its running ok you can, with all them codes id think the throttle is messed up maybe too.
you need a new pcm, its in the air filter box. or a used one from a junk yard, just get one from your same year. a few cross over years. not sure what you got.
you cant use a n/a pcm in a supercharged car, (or the other way) so make sure its the same as far as your engine too.
