need help with the exhaust
kyliek23
anyone know what i should do with my exhaust. i did a temporary fix with like 4 connectors, 6 exhaust clamps and some exhaust tape. after doing that, my car vibrates and you can here it rattle. i hate the noise and feel of my car. any ideas on what i should do, and thats cheap. looking to stay on a decent budget
not sure if it is leaking. but the vibration and noise that it makes when vibrating is what is really getting me. and thats because i have a ton of exhaust clamps on there for an easy fix
Get a piece of cardboard to lay on and snap some pics.
I am sure you will get a lot of suggestions after you post them.
oh sorry didnt specify. replaced my resonator with a thrush glass pack. resonator was squished and welds broke
sounds like your not using the rubber hangers at this pint by the cat. i wired mine up for a temp fix and my god did it vibrate bad.
<a href="http://s1284.photobucket.com/user/Kylie_Mae_Krueger/media/20140618_195147_zps741fc997.jpg.html" target="_blank"><img src="http://i1284.photobucket.com/albums/a579/Kylie_Mae_Krueger/20140618_195147_zps741fc997.jpg" border="0" alt=" photo 20140618_195147_zps741fc997.jpg"/></a>
i called it. your hanger is bolted to the floor and right to the pipe. thats all the racket you hear.
you need to take them off and then weld a rod to the pipe where it will fit the rubber hanger that mounts from under the car.
if the floor part and rubber hanger are still there parts stores sell a clamp style rod.
then they sell a rubber strap you bolt to under the car and clamp the pipe to it. it has a bunch of holes to use for adjustments.
in this pic of my old and new pipes side by side, you can see the old one has a clamp on rod in the same place as the new one's welded on rod. mine rusted off lol
