Need help with exhaust leak
Bluemagic
Ok I know where the exhaust leak is. It's right under my feet because I can hear it and its ANNOYING! Ok so i had it done once before but they didn't do a good job. This is the gasket I need correct?
But my question what are the shapes on the side? Are those bolts?
Use anything you want. You should know something about most ZZP pipes I've encounted, hence the question of which pipe do you have.
Typically the crush zone of the gasket is inside of the ZZP flange and does not get crushed, which is why you don't seal. Take your current gasket and a tube of copper RTV. Wipe your current gasket off with brake clean (if it's metal) and goop the heck out of one side. Put that side against the manifold. Now reach down and goop the hell out of the other side with your finger. Put downpipe in place and torque down. Give it 45 minutes to setup and cure.
Now you are going to irk me. Don't leave out details like that. I'll beat you down, infract you some points, and change your name. :th_laugh-lol3:
Why don't we start at the beginning, please..tell us about your leak and what has been done to date.
Lol ok.
When I bought the car it had u bend delete done and zzp Downpipe. Somewhere along the three years I had it a leak developed at that same exact spot. A local muffler shop welded it for me and everything was fine for a good bit until now. I stopped past another shop and they said one of the bolts are missing. So I now I know welding is not needed (thanks for saving me some money) so I was wondering could I do it or should i let a local auto shop do it?
Two different locations.
By your feet and the first gasket you showed us is the DB to exhaust manifold gasket.
The gasket you bought and the Ubend are under your butthole.
Now if a bolt is missing at the ubend delete, you need a new bolt and the gasket with a little RTV. It's different that the other gasket.
Ok yea I need the one by my feet. Dammit I just tossed the receipt. Time to go trash digging lol. What is the name of the other gasket? I think it needs to be ordered from a local part store correct?
Here's the name of that gasket. LOL
