Need help with antifreeze leaking
bjornbjorn
I have a small amount of antifreeze leaking, it will take 3 days to leak out completely.
I have replaced the thermostat (100K ago), Water Pump (5K ago), and just replaced the coolant elbows.
The leak seams to be coming from the passenger side, in the back under the alternator (might not be where it is originating from but if you look underneath it drips below the alternator area)
What else could this be?
2004 grand prix gt
360,000 kms
It seems that the condenser is leaking quite a bit of water. My understanding is that the AC cannot leak coolant. There is now visable leaks other than from the Condenser which is leaking lots of liquid. Probably too much, other than that there is no leak. Hoses, water pump, coolant elbows, Thermostat, all seem good.
Any other ideas on whats causing 2 liters of coolant gone in a couple of days.
