92bird
I have a z7 intercooled turbo kit on a stock L67 motor (only mod 1.95 yella terra rockers and l76 springs). I'm using a Precision Billet 5858 cea turbo.
The car is mostly street with a rare visit or two to the drag strip. Primary use is street.
I can build 11psi on the brakes with a stock L67 258mm converter with this turbo (slightly smaller than what most go with), and am happy with this setup overall. A tad higher stall wouldn't be bad either, but want to keep it tight for those fun highway pulls..
I expect 425-450 whp out of this max when pushing it harder, but lower boost in daily driver form (~350whp)
I am concerned with cracking a flexplate, and would like to use a meizere billet flex plate when I install my built trans, which requires me to use a 245mm converter pattern. Seems like a properly reman'd stock GPGT 245mm torque converter will stall right where I want it. The big question is, will it handle the power reliably without balooning? I do not plan to lock the TCC at heavy loads, only cruise.
I'm trying to avoid the cost of a billet cover torque converter if I can, but don't want to be tearing the car apart to repair a damaged torque converter because it was not up to the task.
Any advice?
Thanks guys,
Jeramie
Any advice?
Thanks guys,
Jeramie
