I have a 97 GTP and it was running great, but I broke a flex plate and after re installing the engine It idles rough. the motor shakes, but I can't tell if it is misfiring. It is not throwing any trouble lights, of course. the car runs smooth on normal driving but under any acceleration it breaks up, and sounds like it is making a sneezing noise. That is the best way I can describe it. It seems like a vacuum leak or something, it is only getting 13-15 pounds of vac at idle. I tested all the plug wires, and it has new plugs and air and fuel filter. I put a brand new supercharger gasket on it today hoping that would fix it. It has the newer metal lower intake gaskets.
The mods on the car are SLP headers, cat and magnaflow exhaust. short ram air intake, Gen V supercharger, 3.2 pulley, 42 lbs injectors, Intense racing PCM, 150 degree thermostat, 8mm plug wires, autolight plugs.
The car is a 97 GTP 2 door with 97k
Any help would be greatly appreciated but its driving me insane and about to go for a tour on craigslist.
