Need help finding Turbo rebuild kit or replacement turbo!
GHOSTOWLGRID
1990 Pontiac Grand Prix McLaren 3.1L LG5 turbo v6.
Link to engine and turbo info:
http://www.v6z24.com/specs/31turbo
This link is to a rebuild kit, Will this work? If not, what will?
http://gpopshop.com/t2-t25-and-t28-rebild-kits/
(Should I go dynamic or carbon seal?)
More info about my turbo:
ASC Part Number: V24X82467BXXX
Manufacture: Garrett AiResearch
Version: TB02528
Cooling: Water and Oil
Lubrication oil flow: 1.2 L/m SAE 30, 90Degrees C, 2.75 Bar
Bearing: Floating sleeve
Turbo Complete Part number: 465939-2X
CHRA Number: 431876-29
Compressor housing casting number: M24
Compressor A/R: .80
Compressor wheel trim: 70
Compressor wheel diameter Ind/Exd: 1.69”/2.02”
Compressor flow: 29 lbs/Min
Turbine housing casting number: M4
Turbine A/R: .68
Turbine wheel trim: 62
Turbine wheel diameter: 1.64”/2.09”
Wastegate: Internal, vacuum/pressure actuated
