need help asap! Cars shuts off!
reysi1026
ok well i was driving and my 2000 gtp just died, it will turn on and then die again.. I checked the battery connections and they are good. I also checked the fuel pump resistor by bypassing it and still wont stay on.. Im going to check iac and the maf this morning also. Anything else it could be?
If you start it and give it gas up to about 2k rpm's for a few minutes and then let off does it stay running or die again?
Unplug your crank sensor and put a test light or volt meter to it to make sure its working. Also check to see if fuel injectors stay on before it dies. Unplug one connector, it won't hurt it, and have someone put a test light on it to see if it is still getting power even while the car is dying.
Also might want to check the thing the coil packs sit on. Forget its name but the clip on it is known to "c" shape and go bad
