Perry125
Hello, so i installed a pcm which someone loaded the stock tune to, then loaded the dhp 3.0 tune to, then went through it a little bit.
Now after install, i try to do the security relearn-
You crack the driver side window
try to start the car, let it sit in the on position until the security light goes off
turn the key to off
wait 10 seconds
try to start again
let the key fall back to the on position again
wait for the security or the SES light to go off (about 10 minutes)
turn the key off
try to start again, if it cranks, keep cranking till it starts or else you have to start all over again
I have no security light on, and when i try to start it, it sometimes fires for 2 seconds then shuts off.
thanks.
turn the key to off
wait 10 seconds
try to start again
turn the key off
thanks.
