need help a.s.a.p.
dmoney01
im ordering my new pcm from intense and need help on what to put into the tune for it and what some of the things mean such as-Please select your disabled DTC settings:
Disable random/multiple misfire DTC's (ideal for vehicles with aftermarket camshaft) (+$20.00)
Disable rear O2 sensor DTC's (+$20.00)
Disable EGR DTC's (+$20.00)
Disable EVAP DTC's (+$20.00)
witch one should i choose and what does it mean?
and what does this mean- Increase WOT ignition timing tables by up to 1 degree - ideal for naturally aspirated vehicles with any premium fuel, or supercharged vehicles with stock camshaft where 93 or 94 octane fuel is readily available (<b>+$20.00</b>)
any help would be great, thanks
I'll just respond to you're PM here.
DTC = Diagnostic Trouble Codes. (What set's you're SES light off.)
1. If you're getting a cam you want this disabled.
2. If you're going to elimintae the cat you want this disabled.
3. If you're going to be running an intercooler you need to disable it So you would want this disabled.
4. If you're going to eliminate the EVAP on the car you want this disabled.
5 This means that you will be running one degree higher timing when you are at WOT
