Need a writeup
I dont have a write up, but I have swapped out my radiator, but not with the ZZP oversized one. However, it is really straight forward, I think I could almost talk you through it, its that easy.
What you have to watch for is the fans. The fans will rub on the oversized radiator if you do not put some spacers in there to keep it from doing so.
Well I have a 2000 GTP and I bought a oversized radiator for the 97/98 GTP's. I know the fittings are different for the tranny witch is what i wanted, but are all the mounting hardware the same on a 98 as it is on a 2000.
I cant answer that based on "I have actual experience facts" but nothing I have ever read or seen has suggested there is any difference other than the tranny cooler line connections which you already know about and you can get at some parts stores or at the dealership. I picked up some there for like $10 or something for the both of them.
Hopefully someone will step in there that has more concrete facts for you.
