Name this Part and location?
GTPJOE90
I found it in my trunk when i bought the car.... im assuming that it goes on or with it somehow lol. its just a plastic cover or vent of some sort but where does she go?? it says like front and top on the piece. :th_skull:
I have something similar to that in my trunk area, but it has little rubber louvers instead. Mine's on the passenger side just in front of the tail lens assembly behind the carpet. Check there and see if you have a big square hole.
Its basically a part that is not needed unless you like bending upside down to make sure its secured into its spot under the 3rd brake light under the rear dash panel inside the trunk.
Mine came out when I was changing out my 3rd brake light, lights. It never stayed in after that, and I just decided to leave it out and it hasnt been a problem.
Yup, 3rd brake light access cover.
I have no clue if mine is there or not. But if I ever have to take it out, it is not going back in.
Weight reduction FTW!
