Name this bracket.... Thanks
GTPJOE90
IM SORT OF PUZZLED.... WTF does this bracket go??? thanks again :th_thumbsup-wink:
also for the "***** bolt" on the trans that holds the engine together how long of a bolt is it? because when i took it out it feel and got mixed up with other bolts so yeah...... all help is appreciated thank you
Back of the AC compressor bracket. Single hole to the block, two holes to the AC. :eek:
Bolt is the same length as the three from the other side. Then you have the one with the stud on the other side for the neg cable.
nah i got it thanks again man AC BRACKET :) thanks for some reason i wanted to say that bracket was a support for something in the rear of the engine ha guess not thanks man.
It's actually not hard once you get used to the diff cover to engine bracket. Takes a little getting used to. BTW pull your alternator tensioner assembly off and lower you PS pump. You'll have easy access to the engine side bolts of that bracket, through the engine bay.
