    TIPS:
My project car died - my loss, your gain!
ejguillot
Decided to discontinue my project 1998 Buick Regal GS build, and will be parting it out. The following is a partial list of the parts I'll be selling, and I'll be adding more.
While I don't have many posts here, you can find me on regalgs.org with the same username.
All parts located in 33578 zip code. I'm willing to drive 1-2 hours to meet halfway for larger/more expensive purchases (like the transmission). Otherwise buyer pays shipping,
Pictures: Available on request.
Price: If there isn't one listed, make me a reasonable offer. Am willing to consider bundling parts for one price, subject to negotiation
Payment: Paypal if shipped, cash if local.
If you see a description that mentions new, that means it was bought new and installed - so a max of 2000 miles on it.
If you don't see a part listed you may be interested in, ask!
I'll check the forum once a day for private messages.
Fueling:
AEM E85 fuel pump (purchased from ZZP, in basket, about 1500 miles of use)
Brakes/Chassis/Suspension:
GMPP sway bars
Front brake kit - 12" Camaro rotors/pads/calipers/brackets/bushings
Rear boxed trailing arms (not the U channel ones)
Rear strut tower brace with brackets
Body:
Lower rocker panels - plastic covers, complete. Replace your busted/broken ones!
Headlight housings
Entertainment:
Pioneer Appradio 2
12" powered subwoofer
Tuning:
DHP Powrtuner, with analog inputs.
Zeitronix ZT-3 wideband O2
Transmission - bought from Robert Moschella, built to 500HP. $1000
Nearly new A1 Cardone half shafts - about 500 miles on these.
Radiator - oversized 1.25" core radiator, about 500 miles
Radiator cooling fans
Battery - purchased in March this year.
Front Seats - gray leather, heated, power driver and passenger. Driver seat bottom is so so, have a replacement heated seat bottom
Rear Seat - gray leather, fold down 60/40
Interior Trim - in OK shape, ask for details
Aluminum front subframe/engine cradle (with new subframe bushings).
Rear subframe bushings
Spare complete engine
From engine:
Short stack intercooler (injector spacers, FMHE, pump, etc) kit
Northstar TB and LS1 MAF
Ported Gen 3 blower
MPS system pulleys: 3.8, 3.5 x2, 3.2, 2.8
Ported LIM
Dayco 5% overdrive Harmonic balancer and 8 rib pulleys
Blower belts
New engine vacuum harness - MAF/LIM/FPR/BBV, purchased from Intense
42lb injectors(6)
60lb injectors (8)
ARP head stud kit
Reusable rocker arm bolts
Intense S1X cam
105lb springs
Double roller timing chain set
Machined oil pump cover
Oil filter spacer (to clear overdrive pulley)
ZZPerformance oil pressure kit
ZZPerformance hydraulic lifters
ZZPerformance push rods, 6.95" length
Lots of other spare parts like plug wires, coil packs, etc.
3rd icon from the right in the reply box, insert image.
i only do it from a pc. not a phone. so no help on that part.
