my ported blower/alky project
mine sounds like that with my 3.4 setup right now, i dont even know what it is going to sound like with those slits sealed and ~3.0 pulley. niiiiiice.
I will have to fill in my silts some time now. I should have done it when I had the supercharger off. I had not seen anyone run it, so I decided not to do it. It sounds extremely mean for a stock pulley.
its way louder. but please please please!!! prep the blower before you do this....i went thru and ported it out a bit then roughed up the slots with sand paper before setting the quick silver then let it cure for a couple days before it was run. and DO NOT fill in the entine inside....anything will kill th3e rotors if its in the rotor path....just take your time and do it right!
you should have taken pictures of how it looked before you put it on. id like to see how you did it if it was any different from mine.
just to add to my progress..
SWEET AWESOME DIRTY ENGINE BAY!
SWEET OPEN CONE!
DEVILS OWN 150 PSI PUMP! MOUNTED!!
THE SWEET TANK I BOUGHT FOR THE ALKY/METH!
OH ****! ARE THOSE COBRA RIMS?! 17x9? NO WAY!
Did you just zip tie the sensor from the air intake to the wires by the cone?? does it have to be inside the actual tube?? Good idea BTW :th_lightbulb::th_lightbulb::th_lightbulb::th_lightbulb:
yeah, just zip tied it up next to the throttle body. it doesnt need to be anywhere in a tube if you have an open cone and its close to it. if i had some form of a tube i would probably put it in it though.
is that cone open on the top? I saw one online that was... jus seems like that would let leaves,bugs,dead cats in it if it was... I think Im gonna try it out though... let you know how it turns out !
Not gonna help you...you not read the other thread?
And btw...cleanest Engine Bay of the Year Award :D Can I try for the dirtiest?!
If that tanks alum, which thats what it looks like its methanol will eat thur it since its in constant contact unless its anodized. Just want you to watch for that.
had methanol in it for two months. no sign of corrosion on the inside when i dumped it out a week ago.
