my new fog light HID kit !!!!
Doug 97 gtp
i just got my new vvme 8k 880 HID kit and i am installing them tomorrow i was wondering about the 2 metal tabs that are just hanging off of the bulb. ive watched videos on how to install hids and it seems like you just push the metal connectors into the oem harness, Is this right ? also it the blue wire the positave and black negitave.
yes they go into the factory connector, but my vvme 880's didnt fit(those tabs things), i had to make my own connectors to make them work
i took the old bulbs and took the glass off and theres two tabs that stick out and i attached those two tabs to the tabs that stick out of the old bulbs and plugged it in as normal
ohhhhhh ok ill give it a try tomorrow thanks. do the bulbs fit in the sockets with no problem and do i need the little black gromet for the install,
if you mean the black round thing in the first pic^^ then no, i didnt use it, i had no problem with mine. Other then the stupid high beam light coming on when i turn the fogs on
i took off those two metal connectors, stripped them and soldered them to the two fog light wires and heat shrunk tubed and called it a day.
on your fog light harness there is a black wire so match the black to the black! and for the black gromet rubber thing just cut it and throw it away all it does is get in the way. just dont cut the wires!
