Hardonyomom
So i have a 01 gtp and got the 98 venturi bucket and racetronix pump. I have figured out how to put it all back together but running the rewire is tricky. I do not have the zzp rewire which looks like cake to just connect the wires and run like a sound system through the firewall. I have the prj kit which is better but more involved.
I will post pictures here.
The correct way from what im reading and see is to run it under the car(there are 20 zip ties) (the wire has plastic shielding tube covering it)
Anyways, where does the factory wiring begin? if i can figure that out then i can snake my new wire down and start attatching it under the car. Only thing i can think of right now is to fish it behind the fuel pump toward the trunk and maybe it will drop down.
