Just thought I'd share my experience today with the coolant overflow tank. I noticed that it was nearly empty, and the radiator was low. At first I thought about thaoe infernal plastic elbows, but wifey, who is expert at nitpicking (picks the smallest nits :th_tongue2
and closely examing everything looking for probles and faults (especially if it's my fault . . . .) saw wetness on the overflow-tank-to-radiator hose. The hose had gotten itself up against a belt or pully and had a hole worn into it. I decided it would be easier to remove the tank in order to replace the hose, and upon removing the tank I discovered that there was no way a person could see through it, as there was this god-awful dark goo lining the innards of said tank :th_wtf: . SO I decided to clean it. I rinsed it out with a water hose, and the crap didn't budge :th_scratchhead:. I thought, I'd just let it soak for a while so I pluged it up and filled it with a strong solution of TSP and let it sit for an hour. No joy after checking it, the grunge ate the TSP I reckon. SO I added some lye and let it sit again. Looked in there, and lo & behold, the garbage kicked lye's butt :th_question1: Huh? :th_angry-teeth: This stuff must be toxic waste! :th_crossbones1: I took a dowel rod and covered the end with taped-on foam rubber, and tried to scrub on it. I just smeared it around.
I got some on my hands, and it was nearly black. :th_sick1: Looked and felt like old Moly grease. Took some engine cleaner, and Yay!
engine cleaner cuts it! Man, what could it be?
