Multi Function Switch
N8Dogg98
Hello everyone, I recently acquired a 96 Grand Prix GTP for a DD, however the turn signals are finicky and the cruise control no longer works. All the vacuum lines seem to be fine and don't appear to have cracks. I suspect the culprit to be the multi function switch (MFS). I used to have an Intrepid and also own a Mustang, and the column separated in half making it very easy to change the MFS. I noticed that the column in the Grand Prix does not separate in half, and was wondering if anyone could provide some insight on how to remove it so I can gain access to the MFS and replace if necessary.
Thanks
I know multi function switched arent cheap but i used to work at oreilly auto parts and im sure you can get one through dorneman or BWD. not very hard to do.
