Motor/Transmission Mount Replacement
blueguy
The Blue One
I've heard about 91parkave's custom mounts...
I flipped the upper dog bone already, but I get a slight creak from these stockers, I'm just guessing they're shot. I haven't looked...I'll be doing that this weekend when I change the oil and such.
Any recommendations? Just remove and make poly molds and rock those? I've got an upper poly setup on the way, just wanted to take care of the lower half as well.
Mounts (lower) are stupid cheap now if you want to. Jus pour poly underneath the retainer bar for the rear mount. That will limit travel significantly. Also the front mount can drained of hydraulic fluid AMD filled with poly..there is no SR option unfortunately.
Transmission Mount
DEA Part# A2818 $11.93 RockAuto
DEA Part# A2818HD $23.79 RockAuto
Motor Mount
DEA Part# A2796 $19.09 RockAuto
THERE YOU GO LAZY ASS
