dirtracer007
Is there any way to supercharge and normal 3.8l v6, and is so what would it take.
If you have the L36 motor (newer GP) then you cannot add a supercharger. The motor already has a 9:1 compression. You need bring the compression down before you can add a supercharger onto it. I also have not seen any aftermarket superchargers for the newer gp.
What?
meth. better than crack.
2.) The L36 and L26 are 9.5:1 compression engines.
Like your other posts on the subject, that's typical of a programmed "Mr. Goodwrench" response who knows little to nothing about it.
1.) The L36 is not in the newer GP (actually the L26, L36 was 97-03 GPs, 00-05 Impalas, and some Regals that I can't remember the exact years).
3.) The compression does not need to be changed.
4.) Aftermarket superchargers are not needed when we have our choice of either a Gen III Eaton M90 or Gen V Eaton M90 which GM already handily made compatible with our engines.
See what i was told was that on these engines that if you add any kind of forced induction it will burn up the motor like none other. All of the mechanics in my shop have said the same thing.
I have a 2005 GP and i cannot find anything for the car. I want to make it fast and I want to supercharge it but i cant find a supercharger for my motor that i have. I sent out a thred a while back and everyone said that zzperformance had it but I could not find them anywhere what so ever.
I also wanted to change the heads and camshaft out and change out the PCM and beef up the tranny. But i cant find anything anywhere.
Having an 05 "should" make it even easier as you're already drive by wire and shouldn't need to mess with the TB and or MAF. You'll need a Gen V blower and LIM and the rest of the pulley and brackets from the L67/L32.
See what i was told was that on these engines that if you add any kind of forced induction it will burn up the motor like none other. All of the mechanics in my shop have said the same thing. I have a 2005 GP and i cannot find anything for the car. I want to make it fast and I want to supercharge it but i cant find a supercharger for my motor that i have. I sent out a thred a while back and everyone said that zzperformance had it but I could not find them anywhere what so ever. I also wanted to change the heads and camshaft out and change out the PCM and beef up the tranny. But i cant find anything anywhere.
