motor mounts
Chizzler
I have a 99 gtp .To make a long story short while doing intake and oil pan gaskets i fiquired i would change the front motor mount becacause it had a rip in it. i ordered a hydraulic one online and after i put it in it seemed that the passenger side dipped a little lower than the drivers side. Ive seen inoperable parts come off the shelf before so i thought maybe i bought a bad mount. then i decided to replace both engine and tranny mounts with solid rubber mounts and now it seems the motor shifted over a little to the passenger side because there is a very short clearance to the coolant resovoir. any ideas?
when the hydraulic mounts failed it caused the engine to drop. if you replaced both mounts the motor should be now at it oem height. if you want to look further inspect the dogbones.
