More Pics! After months of searching I finally found........
GMR Badass
"The Trifecta".....plus one.
2.93 1" GMR, 3.29 GMR Torsen Diff, GMR 1200hp Aermet input shaft, and 300m output shaft (not zzp chrome moly)
2.93 1" GMR:D:D:D:D
Re: After months of searching I finally found........
I'd bet you sleep with that either under your pillow or on the side your wife used to sleep on.
so send it somewhere so they can reproduce it...
The only special thing is the gears. The chain is the same chain as all the other 3/8 pitch GMR chains.
and you think no one would reproduce those for $200?
I hear its the other way around bill, put money under you pillow at night and the Chain fairy will bring you one. We just didn't tell Greg it was that easy.
Sprockets can be reproduced with little effort. Chain on the other hand requires a ton of money to be fronted to make it happen. If it was the year 2000 and the platform was still in it's prime it would be a worth while venture. Not anymore.
Even ZZP has a $60k investment into their 1" Chain Solution (going to be and epic fail....just calling my shot) and the 1" Morse HyVo "ZX" style chain was too expensive to be reproduced.
