more lights than a xmas tree
got2goat
Ok the old lady tried to cross a set of rail road tracks at mach 3. Now the message display says CHECK ABS, TRAC CONTROL, and a check engine light. They go on and off over bumps. Is there a common connection that I can look for to fix the issue?
abs and tc could be a wheel hub, which is an understandable injury after the incident... dont know if the hub would throw an ses though :confused:
Am I going to have to replace the whole assembly or just a sensor? I'm not hearing any grinding and theres no play in it
You can't really buy the sensor separate from the HUB...you can either...
A) Deal with the light...
OR
B) Drop the coin on a new hub with a new sensor...
If you do...get TIMKIN...from RockAuto Auto Parts or Auto Zone
its def the hub. i personally HATE timkin bearings. never had one go longer then 20k. now my cheap ass napa one with lifetime warrenty has about 60k and still goin strong
