MOOG Sway Bar end links
bbptech
How do u install them? they really arent that straight forward and dont come with directions. Help would appreciated thanks.
front's or rears?
Front's remove old. Put on new bolt, washer, rubber, control arm, rubber, washer, spacer, washer, rubber, sway, rubber, washer, nut
Rears remove old. Put in place and tighten nuts.
but on the 4 rubber bushings they hve a raised part on one end and flush on the other side. does that make sense?
Honestly when I was posting I was laughing because your post wasn't really straightforward about which ones you were replacing. lol
The raised part as mentioned is away from the washer.
