Mods
mpiacent
2002 GP GT and all iv got so far is a FWI and a 180* tstat ... what kind of DP should i get to go with this? if i get one without a cat will it attach to my current one if i get it welded? basically i want the cheapest DP setup i can get ... and does it delete the u-bend if i get a DP? - thanks also is it worth it to port my throttle body? i was thinking of doing that - thanks
porting t/b? no, its a waste of money and time. Your not at that mod level yet.
The zzp d/p doesn't have a u-bend. Get a bolt-in style d/p, this way you can do it yourself and if you decide to take it off you can. You will set the P0420 code weather you get the magnaflow cat or go catless.
