    TIPS:
Modded 98 GTP NIC CAMMED
Shifty
98 grand prix gtp supercharged
3800 series 3 L26 Block 75,271 miles right now
Series 2 L67 Supercharged Heads 3000 miles since full rebuild
included
full valve job, 130# crow cams Valve springs, High performance Viton Valve seals, Titanium Retainers,
Heads were also machined valve guides can handle .610 lift mild porting and polish on exhaust side
Heads were also powdercoated Chrome
other performance mods and parts on engine
New ZZP NIC cam (Non Intercooled Cam)
60# delco Seimens injectors
2 Tuned Pcms 1 for every day driving 1 for racing
3.4 and 3.225 pullys modular switch them out in about 10 minutes
Ported and polished Gen3 supercharger
Ported Lower intake manifold Ported to accept Full intercooler
Ported throttle body
throttle body spacer
Speed Daddy Headers Wrapped in heat wrap
K@N filter
NewRollmaster Double roller timing chain (balance shaft eleminated)
New Oil Pump
New Machined oil pump cover
New LS7 Lifters exact Same as the CORVETTE
New Tensioner
New Pullys
New power steering pump
New water pump
New Alternator
New Battery
New motor mounts
New Ball joints tie rod ends and sway bar links
New aluminum upper intake gaskets not the cheapie plastic ones
New electric 3in Cutout with wireless remote
Transmssion
Rebuilt By Denton's Transmission
Superkit included
Raybestos high Friction clutches
Borg Warner high performance Bands
Transgo Shift kit
Hardend 4th gear
Hardend sprag
Hardend input shaft
Hardend sunshell gear
filled with synthetic trans fluid..
trans has 3000 miles on it
Remote Start Car alarm with pager 2 FOBS
CD player with HD RADIO
XM radio
This car runs and drives perfectly I have seen upwards of 35mpg highway with this car since the build
The idle makes the car literaly sound like a cammed out big block you will get noticed
I dont need to sell the car but if the right deal comes along i may be interested in a trade or i want cash..
clean body but the Rockers under the ground effects are gone completely full disclosure
This Car is Fast Probubly a Mid to Low 13 second car but still manages to break 30mpg when your nice to it..
How are the rockers, rear strut towers, gas cap, and wheel wells? also any videos or engine bay shots? Thanks
As stated the rockers are shot but all rust is hidden by the lower ground effects, rear strut towers look good some light surface rust around the mounts, No rust in gas cap area wheel wells or engine bay..
pm me your email adress i have about 100 pics i took of the engine while putting it together..
