Car seems to run ok and sounded OK but I got check engine light that came one, and it would be flashing if I was over 30 MPH. I had someone plug in the shop's $4,000 computer and it reported very large number of misfire at P0301 and P0304, and some misfire at P0302 and P0305. None at 3 and 6.
Coil, cable, and spark plugs were shifted around, the problem did not follow. Replaced the ignition module, problem did not go away. Checked vacuum and compression, it was all within spec (and out some money for labor since I don't have equipment for vacuum or compression checking). I noticed when mass air flow sensor was unplugged, the misfire stopped.
So how can I check if something's clogged between engine and sensor or if the sensor itself is the problem?
